Engine Removal
the hamiltons
203
I just had the transmission out and had difficulty separating the engine
and transmission. We were sure everything had been disconnected. It was
assumed that the two large alignment pins on either side of the engine were
corroded and stuck in the transmission since they are of dissimilar metals.
After a half hour of soaking with a couple of types of penetrating oil the
two separated and it was corrosion. Anti-seize compound was put on them in
case there has to be a next time!
Al Hamilton
Kingston, Ont
hamilton
Al did you take the transmission out yourself? Just curious.
I have the back of my coach apart still repairing the floor. have a section
cut out and will fit in the new parts within the next couple of days. Very
tedious work since the area is so confined on the floor. I am cutting
half-lap joints both in the floor and on the piece i am fitting in to
hopefully retain the structural integrity of the floor. I plan to secure it
in place with construction adhesive and a few stainless steel screws.
In inspecting the floor underneath the plywood found that the foam
insulation had been installed incorrectly in that area. A hole had been
left open under the fresh water tank in the foam letting water enter under
the floor eventually rotting out that section. It was made worse by a leak
on the topside in the tank. The foam had a factory cut hole,looking like
that section of urethane foam was meant for somewhere else. In addition
there is a slight concave section in the floor support under the fresh water
tank, looks like it was manufactured that way, further compounding the
problem of water settling there. Still trying to get the job finished so
we can come to Kingston. Will keep you informed.
> Al Hamilton
> Kingston, Ont
>hamilton
Oh and another thing Dave. I have heard much made about the floor being
made out of marine plywood. Not true in the case of my 1976. It is 3/4" and
stamped interior with exterior glue. Wonder if anyone else has found the same.
>On Wed, 20 May 1998 09:46:37 -0400 (EDT) "Thomas G. Warner"
>>section
>>Very
>>secure it
>>been
>>under
>>leak
>>like
>>addition
>>water
>>finished so
> In 1977 we took a factory tour as part of a rally in Centerville,
>MI. The workmanship at the factory at Pontiac was typical of the '70s. We
>watched several operations done by disinterested employees that resulted
>in some of the things one discovers when they get behind cabinets and
>under the floors.
>Dave Greenberg
>>engine
>>was
>>engine were
>>metals.
>>oil the
>>them in
>>> Al Hamilton
>>Kingston, Ont
>>>hamilton
