Engine quits
Ron Clark
1,506
North Plains, OR
78 GMC 403 engine dies on the highway. Sometimes restarts by itself,
sometimes restarts after coasting to the shoulder, sometimes requires a
short wait before it restarts. The last time, it didn't restart after
half an hour, so I had it towed 30 miles to a shop that is familiar with
GMCs, but is closed for the weekend. Left them the key and a note. Only
about 50 miles after a fill-up so not out of gas. I didn't check spark or
anything.
Any suggestions?
Ron & Linda Clark
North Plains, ORYGUN
1978 Eleganza II
Ron, if the outside temperature was over 85° or so, I would suspect vapor
lock. If cooler, then I would suspect ignition module or ignition coil.
Either way, check for fuel and check for spark. Then call me. I will guide
you through corrective measures.
> anything.
> Any suggestions?
> Ron & Linda Clark
> 1978 Eleganza II
Vapor lock, fuel pump come to mind.
Len and Pat Novak
1978 GMC Kingsley
The Beast II with dash lights that work and labels you can see!
Fallbrook, CA new email: B52Rule
http://www.gmcmhphotos.com/photos/showgallery.php?cat=4375
www.bdub.net/novak/
-----Original Message-----
From: Gmclist [mailto:gmclist-bounces] On Behalf Of
rallymaster
Sent: Saturday, July 08, 2017 4:25 PM
Subject: [GMCnet] Engine quits
short wait before it restarts. The last time, it didn't restart after half
an hour, so I had it towed 30 miles to a shop that is familiar with GMCs,
but is closed for the weekend. Left them the key and a note. Only about 50
miles after a fill-up so not out of gas. I didn't check spark or anything.
Any suggestions?
Ron & Linda Clark
1978 Eleganza II
This email has been checked for viruses by AVG.
http://www.avg.com
Ron,
Fill the tank ALL the way past full and fill up every 70 miles till Monday
when a shop is open.
Have the shop call me and I will instruct them.
> Len and Pat Novak
> 1978 GMC Kingsley
> www.bdub.net/novak/
> rallymaster
> To: gmclist
> Any suggestions?
> Ron & Linda Clark
> 1978 Eleganza II
> http://www.avg.com
http://www.appliedgmc.com
