Cruising nicely and started to loose some power.
Seen some smoke and pulled off the road. Seemed ok on oil, but driver side front top of engine was wet down to final drive had oil all over the
cover anddripping on ground. Not power
Steering fluid.
Fired it up and here is what it sounded like:
https://youtu.be/lL5w52KpM9g
Had it towed home, pulled valve cover on driver side to see nothing wrong except gasket on that front was messed up when they installed that cover.
I cranked it and all rockers seem to look and operate.
Put valve cover on and engine noise did not show up asap, but came and went quickly and the. Consistant.
Checked assesorries and i dont think that is the issue. Pretty sure it is internal, but not as deep as a rod knock.... but I really have not much
experience in blowing up motors.
So guesses and suggestions welcome. Going to have some better ears come take a listen. And if verdict is not for sure, i will do compression tests
and maybe boriscope next weekend.
Jon Roche
75 palm beach
St. Cloud, MN
Steering fluid.
Jon Roche
75 palm beach
St. Cloud, MN
