AND, some of the new motors have the oil pump on the front of the crank and
use a distributorless ignition, hence no distributor.
Hot Rod Magazine had an article on building a primer for them sing a small
bucket, an old style oil pump driven by a drill, I believe,
and some fittings and hose. I'm glad I'm a dinosaur.
Gary Kosier
77PB w/500Cad
Newark, Ohio
Sent: Saturday, October 21, 2017 3:04 PM
To:
Subject: Re: [GMCnet] Engine Pre Lube Tank
> On many modern engines you have no choice but to use something like this.
> [LS1 for example]
> Also, there are some engines that either won't build pressure or perhaps
> lose psi to the lifter gallery without part of the distributor to block it
> I cant speak to Olds engines specifically though.
> An old stripped distinutor with the cam gear ground off works well.
> If you tee it off the oil presssure system, its proabaly faster than
> pulling and tretiming the distributor.
> I agree that you can make one for much less [much like the brake bleeder
> that was discussed]
> 76 Glenbrook
