I never have used it on the front center, I'll try it tomorrow.
On Mon, Oct 12, 2020 at 9:05 PM Grant Schaffer via Gmclist <
> Yes you are correct there is a bolt / stud what ever you want to call it
> today and a nut that hold the rubber mount on to the mounting plate the
> mounting plate or " front motor mount" is attached to the front of the
> engine right under the water pump. now can anyone tell how one will secure
> the
> mount and the rubber isolator that is attached to the front motor mount to
> the frame cross over? there are two bolts that screw into a metal plate
> that is held in place by the rubber isolator.
> New Front Motor Mounts - GMC Motorhome at JIM K site, WESTAR EM5450 or DEA
> / MARMON RIDE CONTROL A5034 there are 4 holes, the two outside get a stud
> and a nut and possible a couple washers and the two internal that mount
> from the inside of the front crossover though the crossover to these
> threaded
> holes on the rubber " front motor mount" threaded holes get what ? 5/16" -
> 1" ? 3/8" 1? 1/2" -1"?
> 1974 GMC Sequoia 26'
http://www.gmcrvparts.com
