Could someone steer me toward info. on the optimal conversion to electric fuel
pump for a 455 retaining the stock carb?
My intent is to mount a pump down under close to the tanks, preceded by a large
filter (so it doesn't need changing every 12,000 miles). Then I was thinking
about running the fuel line as directly as possible to the carb, perhaps coming
up to the floorboard under the driver's seat then over to the carb fuel inlet
using a race- or aviation-type fuel line very well-insulated. Idea would be to
avoid that long run of steel line which goes all the way to the mechanical pump
at the front of the engine then back along the top to the carb. That has to add
a lot of heat to the fuel, and also lengthen start-up cranking time. I could
probably shorten the fuel's path by 6-8 feet this way.
I gather that many have added an electric pump and am wondering if this is the
way to do it. Also wondering which pump to use, and what sort of safety
switch(s) to incorporate?
Thanks for your help,
Richard
Richard
