Well...I put a fan in front as a booster for A/C and even made the condensate drain drip onto it to spray the condenser. It makes a difference in
traffic to the engine temp but may in fact obstruct some flow at highway speed if it's not running. It was somewhat of a disappointment for all the
work I did to install it. Especially when I turned it on at highway speed and the electrical spike shut the ignition module off for part of a second
and that exploded the muffler. Guess I need to put a cap/condensor on the power feed or ground. Motor home/early iron all need the big diameter
Mercedes Benz fan ($$$)to make a difference. Don't know if any electric will substitute for engine driven unless you are using an aluminum radiator.
Terry Kelpien
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
