EKE install update
ron & gina
397
Hi All,
Finally have EKE installed and hookup.( ended up installing on step in
engine compartment, and hooked power wire up stream of "+" side of coil
which read 12v with engine running ) Engine started with no problem, Checked
dwell and readjusted to 30 and set timing to 13degs. then put EKE online and
did test to see if it would retard, But it was a no go just stayed at
13degs.. Did the diagnostic procedure and came up with a bad transducer.
Called Caspro and they are sending me another transducer. At first he said
that would be $24.00 for the transducer, I said I just got it from you, What
do you mean???? Anyhow he is sending a free replacement with no need to send
mine back. Hope the replacement works or I might need to set my timing at
6degs. for our return trip to Antioch CA. in about two weeks, Since I
already did a first for us by filling the coach with regular gas. But if it
all works it should pay for itself in about 8 trips to CA. 8-)
Ron&Gina
73 Pumpkin-Rose
Ft. Mohave, AZ.
Hi Larry,
Was going to install under seat, But after talking with Caspro went ahead
and installed as they suggest on step,I think I have alot of air movement
there. It is hot air but alot of movement. My under seat compartment is
carpeted and closed in it does get hot there also, with no air movement.
Yeah I was doing the tapping myself, short fast strokes. I thought it was at
least 2 a second??? But might go give it another try, I did try about 8
times till I couldn't take the heat in coach anymore. Don't guess it matters
but did you install transducer in upper or lower hole in head?
Ron&Gina
73 Pumpkin-Rose
Ft. Mohave, AZ.
To:
Sent: Saturday, July 22, 2000 5:42 AM
Subject: Re: GMC: EKE install update
> In a message dated 7/21/00 6:09:12 PM Central Daylight Time,
> 13degs >>
> Ron, did you have someone do the "hammer tapping" while you watched your
> timing marks. With mine, just tapping didn't work. It had to be fast, then
I
> think you might see it retard. I had the same problem, it has to be
several
> taps per second like the instructions say. I installed mine under my seat,
on
> top of the seat base, used heavy duty velcro. I know others installed in
the
> engine room, but that did not qualify as the "coolest and driest" location
on
> my coach.
> Larry Nelson
> Springfield, MO
> GMC 1975 Palm Beach
> WB0JOT
Thats a better spot in the openness of cab of coach!! Thats for sure the
coolest and driest
Yeah I'm going to give it another try with two people this time, If it works
I'll already have a spare transducer. 8-)
You have a great weekend!!!
Ron&Gina
73 Pumpkin-Rose
Ft. Mohave, AZ.
To:
Sent: Saturday, July 22, 2000 10:11 AM
> Ron, my unit sets ON TOP of the seat base, not inside the compartment. In
> other words, I can see it when I look down from the seat (barely). As for
the
> tapping, have someone tap it very fast and you might me surprised to see
it
> retard.
> Larry Nelson
> Springfield, MO
> GMC 1975 Palm Beach
> WB0JOT
