EKE fine tuning
nate chase
553
Those of you with EKE installed.... Do
you notice about 1-2 seconds worth of
pings when you take off especially under
load (IE. up a hill, accelerating
quickly, etc.)? I know it has to detect
some pings to retard the spark but
wondered how much or how long you have
noticed?
I have my timing at about 12 degrees
advanced and the sensitivity adj. at MAX
(4+). Been playing with the other
adjustment and have found if I set it
too high I loose performance going up
hills (pings for 1-2 sec). If I set it
too low I get alot of pinging (more like
3-5 sec). Seems if I set it about 3
there is a happy medium but still hear a
few seconds of pings regardless.
Does anyone know the vendor of the ping
detector? I wonder if putting a second
one (wired in parallel since there's
only one wire) on the other head would
help detect pings quicker? Just a
thought...
Nate '75GB (Everyone's 2 cents will be
appreciated) Omaha
Nate,
It sounds to me like you are asking the EKE to eliminate beyond its
capacity. I'd retard the timing to 10 or 11 degrees, set the EKE retard to
3 IIRC and set the sensitivity to about mid point. FYI my much admired
mechanic says he has done a number of engines with burned pistons that have
EKE's installed. Mine is set to initially ping only under a very heavy load
and only 1 or two ping s to cause it to retard. I've got more power since I
installed it than I've ever had even though I switched to regular gas.
Bob McLaughlin
- -----Original Message-----
[mailto:owner-gmcmotorhome]On Behalf Of chase
Sent: Monday, June 05, 2000 11:02 AM
To: 'GMC'
Subject: GMC: EKE fine tuning
noticed?
thought...
appreciated) Omaha
I have mine at about 15 degrees before, as checked by Lamy, and also
that i can hear about 1 to two seconds then the ping goes away.
Don't know exactly how long, but i think I have it set to about 3
1/2+ or so on the dial.
al
>noticed?
>thought...
>appreciated) Omaha
