EBC Yellowstuff brake pads part number...do you have it?
6cuda61
418
Anyone know off hand what the EBC number is for the Yellowstuff pads or is their something better? If so make and part # please.....thanks
Rich Mondor,
Brockville, ON
77 Hughes 2600
Depends on which size calipers that you are using. 80MM uses the DP41145R (use 76 eldorado) If you are using the 72 or 63MM then you can use the DP41146R (use 84 Monte Carlo). You can check with Jim K to verify the numbers.
J.R. Wright
GMC Great Laker MHC
GMCGL Tech Editor
GMCMI
78 GMC Buskirk 29.5’ Stretch
75 GMC Avion (Under Reconstruction)
Michigan
> Rich Mondor,
> Brockville, ON
> 77 Hughes 2600
When the EBC yellow pads first showed up, I, with some helpers, ran tests
to see if they were really any good:
http://www.gmcmhphotos.com/photos/g4642-calibrated-brake-tests.html
After putting about 20,000 miles on them, I when through a similar series
of tests, the results of which I no longer know where to find. But I do
remember the bottom lines: They were COMPLETELY worn out at that mileage
(which is the limit of the EBC warranty). The friction material was
breaking away from the steel pads. And the braking results were back down
by the 5% or so advantage they had over the Performance Frictions they
replaced.
I put new Performance Frictions D052's back on my GMC (with their lifetime
warranty) and have never looked back.
Applied GMC sells the Yellow EBC's and, probably, the Performance Frictions
(O'Reilly's definitely does). I suspect the price is about the same. Your
choice; I've made mine.
On Sat, May 23, 2020 at 8:42 PM 6cuda6--- via Gmclist <
> Rich Mondor,
> Brockville, ON
> 77 Hughes 2600
Ken:
I’ve been a fan of Performance Friction and Hawk brake pads for a while.
There’s a newcomer on the scene, and it’s NRS
Home - NRS Brakes https://nrsbrakes.com/
We have a set on my car and my wife’s car and are quite pleased. They address the rust jacking and the adhesion directly.
There’s also this (and I don’t remember if it’s been here or in one of the other communities I follow).
https://www.youtube.com/watch?v=DZ8O2tJOGLE https://www.youtube.com/watch?v=DZ8O2tJOGLE
I’ve had the same experience you have with EBC, and it’s why I avoid them.
Dolph
DE AD0LF
Wheeling, West Virginia
1977 26’ ex-PalmBeach
“The Aluminum and Fiberglass Mistress”
"--OO--[]---O-"
> replaced.
> Ken H.
>> Rich Mondor,
>> Brockville, ON
>> 77 Hughes 2600
>> GMCnet mailing list
Hi, Jim.
Can you suggest brands and part numbers for those pads and shoes you recommend, please?
D C "Mac" Macdonald
Amateur Radio K2GKK
Since 30 November '53
USAF and FAA, Retired
Member GMCMI & Classics
Oklahoma City, OK
"The Money Pit"
TZE166V101966
'76 ex-Palm Beach
k2gkk + hotmail dot com
Sent: Saturday, May 23, 2020 22:18
Cc: James Hupy
Subject: Re: [GMCnet] EBC Yellowstuff brake pads part number...do you have it?
Anything that improves the braking effort very much over stock, has to come
at a price. Usually, faster pad wear. I personally use ONLY RIVETED Semi
metallic linings. There are several brands out there that work well. They
do make more noise, but work well in any weather. Anything you use will
have good points as well as bad points.
Salem,, Oregon
Salem,Oregon
On Sat, May 23, 2020, 7:50 PM Dolph Santorine via Gmclist <
> Ken:
> https://www.youtube.com/watch?v=DZ8O2tJOGLE <
> https://www.youtube.com/watch?v=DZ8O2tJOGLE>
> Dolph
> DE AD0LF
> "--OO--[]---O-"
> > On May 23, 2020, at 10:08 PM, Ken Henderson via Gmclist <
> series
> down
> > replaced.
> lifetime
> Frictions
> Your
> > Ken H.
> is
> >> Rich Mondor,
> >> Brockville, ON
> >> 77 Hughes 2600
> >> GMCnet mailing list
Let me see what I can find.
Salem, Oregon
> Hi, Jim.
> recommend, please?
> D C "Mac" Macdonald
> Amateur Radio K2GKK
> Oklahoma City, OK
> "The Money Pit"
> TZE166V101966
> '76 ex-Palm Beach
> *From:* Gmclist on behalf of James Hupy
> via Gmclist
> *Sent:* Saturday, May 23, 2020 22:18
> *To:* gmclist
> *Cc:* James Hupy
> *Subject:* Re: [GMCnet] EBC Yellowstuff brake pads part number...do you
> have it?
> Jim Hupy
> Salem,, Oregon
Hi Ken,
I have raced on EBC's, Ferodo, PF and a few other brake pads on my motorcycles [when i was doing it professionally a few years back] and agree with
wear characteristics as stated.
The Performance Friction number you state here, is that for stock calipers or 80mm calipers?
> replaced.
> Ken H.
> > Rich Mondor,
> > Brockville, ON
> > 77 Hughes 2600
Rich Mondor,
Brockville, ON
77 Hughes 2600
Great test video.... NRS doesnt list a brake pads for older vehicles but i have inquired with them to see what, if anything can be done.
> Ken:
> Home - NRS Brakes
> Dolph
> DE AD0LF
> "--OO--[]---O-"
> > replaced.
> > Ken H.
> >> Rich Mondor,
> >> Brockville, ON
> >> 77 Hughes 2600
> >> GMCnet mailing list
Rich Mondor,
Brockville, ON
77 Hughes 2600
The PF D052, which may have changed by now, fit both the 80mm and OEM
calipers. Best you visit here for current numbers for the calipers you're
using:
https://pfcbrakes.com/parts-finder
On Sun, May 24, 2020 at 6:53 AM 6cuda6--- via Gmclist <
> Hi Ken,
> with
> or 80mm calipers?
> series
> down
> > replaced.
> lifetime
> Frictions
> Your
> > Ken H.
> or is
> > > Rich Mondor,
> > > Brockville, ON
> > > 77 Hughes 2600
> > > GMCnet mailing list
> Rich Mondor,
> Brockville, ON
> 77 Hughes 2600
This is directed mostly at Mac.
Master cylinder. Brake Best Select
NMC 11319
RAYBESTOS PADS PGD 52M
BOSCH DISC PADS (yellow) Quiet Cast
BP 370
CENTRIC CALIPERS 141.66019 and 141.66020 ( right and left)
RAYBESTOS REAR SHOES (riveted)
462PG
This should get you started.
Salem, Oregon
On Sun, May 24, 2020, 5:07 AM Ken Henderson via Gmclist <
> using:
> Ken H.
> > Hi Ken,
> agree
> > with
> calipers
> > or 80mm calipers?
> tests
> > series
> do
> mileage
> > down
> > > replaced.
> > lifetime
> > Frictions
> > Your
> > > Ken H.
> > or is
> > > > Rich Mondor,
> > > > Brockville, ON
> > > > 77 Hughes 2600
> > > > GMCnet mailing list
> > > GMCnet mailing list
> > Rich Mondor,
> > Brockville, ON
> > 77 Hughes 2600
