DYNO RUN 1972 455 .060 bore with 1968 crank, stock CI intake
grant schaffer
94
1
Well fellow MO HOE'rs its done, total geek out day for me and my engine. the best experience I have had and a slight tear.
My engine came from Gary Worbeck I have rebuilt the entire engine. bored .060 over slight "J" head modification, decked and EGR ports blocked 3 angle
valve job. stock cast iron intake, q-JEt and Springfield ign and coil. double roller timing chain and RV cam Speed Pro CS1024R. 1500-4000 RPM
280intake/ 290 exhaust Advanced duration @ .050 204 intake/ 214 exhaust, Valve lift .448 intake/ .472 exhaust Lobe CL 112. sealed power hydraulic
lifters HT 951
inertia factor is at .87 on the DYNO. I am absolutely impressed. totally blows away stock figures. now time to find the right gearing. the Manny
Tranny should work well with this! Peak HP 294 @ 3800 RPM PEak TQ 469.2 @ 2800 RPM.
DATE 5/7/20
TIME 12:37
TIMING 35 DEGREES
FUEL PUMP GAS 86 OCTANE Q-JET 750 CFM Long tube headers
ENGINE 455 OLDSMOBILE .060 OVER J HEADS EGR BLOCKED OFF Melling High volume oil pump
SPEED RP - CBTrq lb-ft -CBPwr CHp - BSFC lb/Hphpr -Fuel lb/HR- AIR FUEL DRI -AIR FUEL PASS- Oil Pr psi -Water Degrees
1700 411.8 133.3 0.521 65.3 10.89 11.79 61.5 174
1800 413.4 141.7 0.534 65.9 10.6 11.09 61.7 174
1900 416.1 150.5 0.525 68.8 10.33 10.68 61.8 174
2000 422.4 160.8 0.519 72.3 10.17 10.49 62.3 174
2100 429.9 171.9 0.517 77 10 10.55 62.5 174
2200 436.6 182.9 0.498 79.3 10.22 10.76 62.6 174
2300 443.5 194.2 0.482 81.7 10.61 11.06 62.7 174
2400 452.7 206.9 0.48 86.3 10.95 11.28 62.2 174
2500 460.2 219 0.463 88.7 11.16 11.32 61.9 174
2600 465.4 230.4 0.46 93.3 11.39 11.57 61.9 174
2700 468.7 240.9 0.451 96.3 11.72 11.56 62.2 174
2800 469.2 250.1 0.447 99.8 11.89 11.83 62.3 174
2900 467.6 258.2 0.449 103.8 11.84 11.77 62.3 174
3000 463.6 264.8 0.461 110.3 12 11.96 62.3 174
3100 458.9 270.9 0.488 119.6 12.09 11.99 62.3 174
3200 455.1 277.3 0.524 131.3 12.05 12.03 62.8 174
3300 449.6 282.5 0.543 139.4 12.17 12.15 63.7 174
3400 442 286.1 0.547 142.9 12.27 12.15 64.4 174
3500 433.4 288.8 0.542 143.9 12.43 12.41 65 174
3600 424.4 290.9 0.539 144.1 12.3 12.46 65.5 174
3700 415.8 292.9 0.542 145.8 12.11 12.54 65.7 174
3800 406.3 294 0.549 148.8 12.11 12.73 65.8 174
3900 394.7 293.1 0.572 155.8 12.02 12.84 64.5 174
4000 382.3 291.2 0.604 163.9 11.93 13.07 63.1 175
1974 GMC Sequoia 26'
WOW! What a torque monster!
D C "Mac" Macdonald
Amateur Radio K2GKK
Since 30 November '53
USAF and FAA, Retired
Member GMCMI & Classics
Oklahoma City, OK
"The Money Pit"
TZE166V101966
'76 ex-Palm Beach
k2gkk + hotmail dot com
From: Gmclist on behalf of Grant Schaffer via Gmclist
Sent: Thursday, May 7, 2020 20:26
Cc: Grant Schaffer
Subject: [GMCnet] DYNO RUN 1972 455 .060 bore with 1968 crank, stock CI intake
lifters HT 951
DATE 5/7/20
TIME 12:37
TIMING 35 DEGREES
Travis,
Some info on rebuilt engine. Info you may need on your rebuild.
Gary
Gary Coaster / Reno, NV
1977 GMC Eleganza ll
GMC RV Day Night Shade Sales
GMCShades
www.GMCMotorhomemarketplace.com/GMC_Shades/
> lifters HT 951
> DATE 5/7/20
> TIME 12:37
> TIMING 35 DEGREES
Grant, Let me supply the LSD Final drive.
We are moving several as it does help.
On Thu, May 7, 2020 at 9:24 PM Gary via Gmclist
wrote:
> Travis,
> Gary
> GMCShades
> > On May 7, 2020, at 6:27 PM, Grant Schaffer via Gmclist <
> > lifters HT 951
> @ 2800 RPM.
> > DATE 5/7/20
> > TIME 12:37
> > TIMING 35 DEGREES
http://www.gmcrvparts.com
Yes Jim, that is next on my list to figure out, Withe these numbers, I am not sure if the 3.70 is the right choice but maybe we should have that
discussion. I will also be getting the limited slip. I am most interested in the torque curve in this motor as it is almost flat above 400 ft/#. Kinda
crazy. In either case its about matching the right gearing for 60-65 MPH and towing.
Out side of break in which there were issues, from builder missed the oil plug on the back of the block, pan was bent, lost 10 gallons of fuel on the
floor to break in needed the stock oil filter location to pass by the headers, I dont have to worry about the engine when installed.
today i will be getting prices on Frank Condos hoist so plans for reinstall are moving forward.
Gents in my geekness on this issue I believe the dyno runs are important to match your final drive with the engine we are re-manufacturing in our
coaches as well as suspected useage. I am excited about this process. and will update as things move forward.
I did not expect these results by the way. Quite honestly i didnt know what to expect.
Husker,
Go with the 3.70 because that will put you in the torque band at cruise. Torque peak is where the volumetric efficiency is best. If you went to a
4.10, that might be nice if you are towing much because you would be far enough up the torque curve to maybe get so "torque back-up". This is nice
thing because when the load increases the slow down brings in more torque and that is what you want just then.
Is it dented here? Drivers side at differential?
http://www.gmcmhphotos.com/photos/oil-pan-dent/p61314-image65.html
> Kinda crazy. In either case its about matching the right gearing for 60-65 MPH and towing.
> the floor to break in needed the stock oil filter location to pass by the headers, I dont have to worry about the engine when installed.
C. Boyd
76 Crestmont
East Tennessee
On Fri, May 8, 2020 at 10:58 AM Charles Boyd via Gmclist <
> Re. Gear ratio, we find that there are many times you’ll be below 60mph
> and having the 3.70 does help.
out of every 20 gears, we sell only one or two.
RPM difference 3.55 / 3.70 is only
130-140 RPM at 65mph but the torque
Is sensitive.
> ft/#.
> what to expect.
> C. Boyd
> 76 Crestmont
> East Tennessee
