Thank all of you for your advise and experience. The beads and good tires it is for me.
Chaplain Randy Hecht
Roswell, GA
Chaplains are ready to Listen when you're ready to talk.
1974 Canyon Lakes GMC the Unicorn Express
80mm Front Disc and a work in progress
> One more item, the Centramatic wheel balance rings run right at $200 +/- ,
> a good tire is cheaper.
> J.R. Wright
> GMC Great Laker
> GMCGL Tech Editor
> GMC Eastern States
> GMCMHI
> TZE Zone Restorations
> 78 Buskirk Custom 29.5' Stretch
> 75 Avion (Under going Frame up Restoration)
>> To All,
>> We bought our first GMC in August of 1998. It came Goodyear G169 225 75R
>> 16.5 LRE tires on steel rims. Those were all steel tires and along with
>> the steel rims it was not a good ride or steer. First change was to a set
>> of Alcoa Classic rims and put a set of Firestone RTS 225 75R 16 LRE tires.
>> Tire construction was a steel tread with poly side walls which most
>> including myself consider the best combination to run and I have run every
>> possible tire combination out there, all steel, poly in front and steel in
>> back and all poly tires. That coach-tire combination was a dream to
>> drive. The one thing that I have never had was a problem was balancing
>> tires on the coach.
>> Now this is a "personal opinion" or as most would say IMHO! I only have
>> purchased tires such as Firestone, Goodyear, BF Goodrich and Michelin (All
>> LRE range tires, your fooling yourself in buying LRD tires). I only buy
>> tires that have a similar build date and are fresh from the manufacturer.
>> The last few sets have been purchased from Discount Tire. Up until last
>> year I was driving 10K+ miles each year for the past 10 years. Before 2007
>> we were a 3K +/- mile a year. The drop is because we stopped driving the
>> coach FL till 2009 and out to AZ and back each winter.
>> Over the years I have seen on this site the large number of brands of
>> tires that you out there have purchased and used. Now most of you are low
>> mileage per year users of your coach and your tires age out before the
>> tread does. I can see that SOB tires serve you well for the miles that you
>> drive and some have gotten excellent service for greater miles. Everyone
>> has their personal choice or price range!
>> Let's get to tire balance. All of the national tire selling chains have
>> the correct balancer to correctly do the tire and the tech may be less
>> talented. Smaller tire shops are at times not as well equiped with the
>> newer stuff. The balancing beads works well in most applications and 4 OZ
>> of beads seems to work best. The Walmart sold Airsoft
>> beads seems to work as well as the high dollar beads sold at the tire
>> stores. The bottom line here is iif the tire shop can't balance the tire
>> correctly then ask for a new tire or go someplace that will sell you the
>> tire of your choice balanced correctly.
>> Again that is IMHO on tires and yours could or may vary!
>> J.R. Wright
>> GMC Great Laker
>> GMCGL Tech Editor
>> GMC Eastern States
>> GMCMHI
>> On Tue, Mar 3, 2020 at 6:44 AM Bruce Hislop via Gmclist <
>>> Seems like Randy's emails to the list are not posting. Here is his
>>> followup which he emailed to me as well.
>>> Sorry folks, my first email didn't post.
>>> I was asking what any thought of these dynamic wheel balancers and did
>>> anyone have experience with them. I like simple solutions that work across
>>> things that have to be changed now and then. I understand these are
>>> priced up there, I think this set is about $200 for two wheels, making it
>>> about
>>> $600 for all six wheels. Which if getting tires balanced correctly is a
>>> issue, these may do the job when when the tires are balanced as best some
>>> places can. I'm not sure is why I am reaching out.
>>> Thanks, all of your input is well appreciated as I work to get my coach
>>> up and traveling this year.
>>> Randy
>>> Randy, Here is the thread I started last August on the subject. They
>>> seem to work, but the consensus on the Forum is to us 4 Oz of Airsoft
>>> plastic BB
>>> balls in each tire. A bottle of them is under 10.00 at Walmart. Except
>>> for a bit of vibration while accelerating through 35-40mph they work great
>>> for me.
http://gmc.mybirdfeeder.net/GMCforum/index.php?t=msg&th=42729&goto=346224&rid=1480
>>> My followup post with airsoft BB's
http://gmc.mybirdfeeder.net/GMCforum/index.php?t=msg&th=42759&goto=346457&rid=1480
>>> Bruce Hislop
>>> ON Canada
>>> 77PB, 455 Dick P. rebuilt, DynamicEFI EBL EFI & ESC.1 ton front end
>>> My Staff says I never listen to them, or something like that
>>> _______________________________________________
>>> GMCnet mailing list
>>> Unsubscribe or Change List Options:
