Dwell setting?
hatter ed
40
I installed a new coil and bought a new set of points, cap and rotor last
night. The manual says to set the points at .016 gap and 30 degree dwell.
I put the dwell meter on and it read ~ 24 degrees. When I tried to adjust
it to 30 degrees it would start missing and die. The instructions on the
new points said that you could turn the allen wrench clockwise until it
started missing and then back half a turn, so that is how I left it.
My question is why can I not get the dwell set at 30 degrees and what affect
does not having the dwell set properly do? Poor gas mileage? Engine run to
hot?
I did not install the new points, cap or rotor since the old ones looked
new, and I didn't want to miss with the new points when I couldn't get old
ones set.
Thanks
Ed Hatter
73 Glacier
Omaha, NE
>ones set.
I would install the new points and condenser before trying to set the
dwell. Its very hard to get a good dwell reading by "gapping" an old set of
points. The surface of the contacts wears un-evenly so you cant accurately
measure the gap with a feeler gauge. I am guessing that you will be able to
set the new points without a problem.
If the old points are burned or worn additional resistance may be
introducing some inaccuracy in the readings you are seeing on your dwell
meter too. There is a possibility that you have a problem with your
condenser and/or coil that would give you inaccurate dwell readings.
Keep in mind that changing the dwell will also change the timing. Be sure
to check the timing after you have the dwell set properly.
Dave
73 Sequoia
What I would recommend to anyone is change to electronic ignition. I have a
'74, you all ready "electrondon" - so says the title. Anyway, the 75 Olds
HEI works like a champ -- better running and better gas mileage. Plus,
longer between tune-ups. Don't quibble. Bite the bullet.
With best regards; I'm
Sincerely,
Sam Pickens
picksam
> From: Hatter, Ed
> To: 'gmcmotorhome'
> Subject: GMC: Dwell setting?
> Date: Thursday, July 15, 1999 8:57 AM
dwell.
adjust
affect
to
> hot?
old
> ones set.
> Thanks
> Ed Hatter
> 73 Glacier
> Omaha, NE
Thats what I did. I used a Cardone 1893 distributor (75 Olds Toronado) and
replaced the vacuum advance with a Delco 1973577 vacuum advance.
Dave
73 Sequoia
Ed, No expert on this, But I once had the same problem on a car and found
the plate that the points sit on was worn had it replaced and all was ok.
Just a thought!!
Ron&Gina
73 Pumpkin-Rose
Fort Mohave,AZ
To:
Sent: Thursday, July 15, 1999 5:57 AM
affect
to
> hot?
> ones set.
> Thanks
> Ed Hatter
> 73 Glacier
> Omaha, NE
Ed
I would suggest that you set the dwell to 30 degrees-
even with the engine starting to miss ---THEM check
the timing with the new dwell setting -- I bet that
the timming will be off.
The proper sequence is to set dwell -- then set timing
because changing the dwell --> changes the timing.
Pete Papas-->http://members.tripod.com/~mehawk_ii/index.html
. ___________ (MY TOYS) (904)672-0571
./_][__][] []| 1973 GMC M/H 1976 Bi-Centennial Harley M/C
.*O-------OO-* Painted Desert 1979 280ZX Datsun (1 of 1000)
Do You Yahoo!?
Emery and others,
How often should you change the points, rotor etc.? I mean in miles?
Ricard Waters '76 PB, Troy, MI
> Just as a matter of preventative maintenance you should change the points,
> capacitor, rotor and cap periodically.
