Drivers window rubber
Rich Kinas
Member
Jul 30, 2019
110
1
18
Second question.... As it relates to the drivers and passenger windows (the three glass section windows, again do these have a specific name?) I have
the material to replace the slider gaskets for both windows (Thanks J. Bounds) and the cat wisker wipers that goes vertical between the fixed window
and the sliding window. My question is how is the top window fixed into the frame? It looks like a kind of lock ring rubber gasket, but I cant be
sure, and I would really like to remove it and reseal under it, but cant risk damaging it during removal it I can't get a replacement. Does any know
whats what in relation to this window (whats actually sealing it, are there replacements, etc)?
Thanks everyone,
Rich Kinas
Rich Kinas
1976 Elaganza II
Orlando, FL
Call Jim Bounds in Orlando at The CO-OP @ 407 857-5777. Check out the website at: http://www.gmccoop.com
J.R. Wright
GMC Great Laker MHC
GMCGL Tech Editor
GMCMI
78 GMC Buskirk 29.5’ Stretch
75 GMC Avion (Under Reconstruction)
Michigan
> Thanks everyone,
> Rich Kinas
> Rich Kinas
> 1976 Elaganza II
> Orlando, FL
The window is held in place by a u-shaped rubber channel strip. The problem is, that it appears the whole window frame would need to be removed to
change the seal on the fixed glass. At the rear of the frame by the horizontal division bar, you will see the frame is cut to allow the necessary
bending to allow bote the upper and lower fixed panes to be removed and resealed.
The windshield installer folks at Mansfield recommended that I trim the part of the seal on mine that has pulled free, and fill the small gap
remaining with black automotive urethane glass adhesive. That will be the path I pursue on my coach.
I had this same question a week ago -- http://gmc.mybirdfeeder.net/GMCforum/index.php?t=msg&th=43004&start=0&rid=5434
When I finish the job, I will post the results here.
-Dave
1978 Transmode (403)
Pittsburgh, PA
