Hi Emry. All I know is that when I got the new gears and chain I also got a new
drive axle for the right side. If I remember correctly if was slightly larger in
diameter. I will check the two together when I get the other one out.. This may
be a few days. Hanna goes into the hospital tomorrow and surgery on Tuesday. I
will stay with my son in Santa Barbara instead of the hour drive each day. One
of our friends will care for Barney. JUst a thought why would I get a new drive
axle with the gears, if the old one was ok. Chuck
> willa indicated that Caspro has replacement drive axles that are
> larger in diameter.
> Chuck - are you sure that your drive axles are larger than stock? I believe
> that I have the latest Caspro catalog and they do not show any axles. I have
> also not heard of any problems with axles other than the loosening of the
> bolts to the final drive (which is why you should use new bolts and special
> lock washers) and CV joint problems (usually caused by a cracked boot).
> Emery Stora
> 77 Kingsley
> Santa Fe, NM
> larger in diameter.
> Emery Stora
> 77 Kingsley
> Santa Fe, NM
