Sorry if I missed this somewhere but what do you guys use, chemistry or other to get all of the layers or silicone, tar, crud ect,,, off the drip rails and other roof breaches? Thanks
Gasoline will soften up and eventually remove silicone. Usually I start with WD-40, then mineral spirits, then gas, then methanol, then paint thinner. Tar coatings I use a MAPP gas torch real fast and hot, get the top smoking, then scrape it with a putty knife. Then gas to clean up the surface, just be careful to be finished with the torch first
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
