And still vibrate? I thought the alloy wheels were supposed to eliminate the balance problems associated with steel wheels. Dang.
So it must be the rubber is out of balance.
I have on my list to attach my son's GoPro on the outside of the coach at the 4 corners to observe a vibration I have right at ~62mph
I had glass or ceramic (can't remember the brand) balance beads in the tires for maybe 5 years with no issues. Then about 2018 I started to get a shake, which seem to usually clear when I ran over a set or railway tracks. So I was thinking that maybe some was had condensed in one or more tires causing the beads to clump together and the RR tracks would shake them loose again.
The vibration starts about 60 and usually clears around 70mph. I believe it's from the rear, but the odd time I feel it in the steering wheel.
- So I had the beads removed and the tires dynamically balanced. When I returned to pick up the coach the tire guy was just finishing up. I noticed he was installing the aftermarket tire pressure monitors, but didn't think anything of it at the time.
- Left for the Maritimes and it shook worse than ever!. It occurred to me when we returned that they likely balanced the tires with the TPMS removed, when when re-installed it made them out of balance. I went back to the tire place and the guy argued it would make no difference. So I said, well I'll pay to have one tested and of course it was off by one ounce right were the stem and the TPMS is. They still disagreed so I paid to have it done again and every one was off in the same place. However this did not fix the problem.
- So I paid to have the tires cracked off the bead on one side and added 4 oz of soft beads. Still no difference.
- About 2020 I installed DaveL's large mid axle disk brakes. So that changed the existing mid axle disk brakes. There was no change in the shake.
- 2022 I installed Al Branscombe's Electric Parking brake system, so that changed the disks etc from the rear-rear brakes. Still had a vibration.
- 2023 I installed 6 new Toyo tires and put 4 oz of soft beads back in (new beads). Still no difference.
-Edit: I also pulled all the shocks to be sure there was firm resistance throughout the stroke in both directions on all of them. They seem fine.
Miffed....
