DOT Brake Fluid 5.1 and Lenzi's Disk Brake
emerystora
14,608
2
1
I recently installed Dave Lenzi’s new rear disk brake kit. I had a 4 wheel disk brake from TSM (The Streetrod Mfg. CO)
It has worked well but it had 11 inch disks and Dave’s has a 13 inch disk with dual piston calipers — very large. It was actually designed for a large heavy truck with dual wheels.
I installed the new system on my mid axle and eliminated the brakes from the rear axle. I have better braking with just the single disk on the rear even when towing my toad in the mountains of Colorado..
I am waiting for Dave to finish his caliper for the hydraulic parking brake and then I will add that. His disk brake kit already has a place to mount it.
I decided to switch to the new DOT 5.1 Brake Fluid. NOTE: this is NOT a silicone fluid. It is compatible with DOT 2, 3 and 4.
I flushed the whole system and installed fluid made by Wagner. There is a bargain on Amazon. $11.98 for a 32 ounce container with free shipping if you have Primer. Much, much cheaper
that I have found 5.1 anywhere else.
Emery Stora
77 Kingsley
Frederick, CO
I am tired of having my emails to the GMC list go through signed delbert lecky instead of Emery Stora. I don’t know if someone started that as a gag but its gone on too long.
If the list manager cannot fix the problem I guess I’ll have to change my email name and see if that will take care of it!
Emery Stora
77 Kingsley
Frederick, CO
> delbert lecky via Gmc ?
> Where did that come from?
> Larry
> 78 Royale w/500 Caddy
> Menomonie, WI.
It’s no big deal as your sigline clears it up. Besides, I bet most can tell
just by reading your posts that it’s u
Sully
On Mon, Aug 27, 2018 at 6:15 PM Emery Stora via Gmclist <
> Emery Stora
> 77 Kingsley
> Frederick, CO
> > Larry
> > Menomonie, WI.
Send Eugene a note and have him delete ALL 3 Delbert user name entries. Then the next time you post your correct name should be picked up correctly
just like a new user.
Be glad you weren't saddled with Gumphrey :)
--johnny
Braselton, Ga.
