Door seal rubber
boybach
1,032
194
63
Yes, after a heavy rain i find the entrance carpet damp and also the carpeted bottom half of the door. I believe this is due to the rubber gasket
glued to the door frame being so tired that it no longer does the job.
Any generic suggestions for replacement?
Larry
Larry - Victoria BC -
1977 ex-Palm Beach "Ol' Leaky" 40,000 miles, PO said everything working but forgot the word NOT. Atwood helium fridge, water heater & furnace. SS
exhaust system, Onan, Iota Converter, R134A, New fuel lines & heat exchange hoses
Jim K. at Applied GMC use to have them. Call Jim K.
Thanks Ken,
Yes we still stock them.
Also small rain shield that mounts above the door is very good to have.
All are on our website www.appliedrv.com
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
Jim Kanomata ASE
http://www.gmcrvparts.com
Jim I'll check your site but using the "old"? URL https://www.gmcrvparts.com/
the link you listed "www.appliedrv.com" didn't work, just a heads up.
Larry
> Thanks Ken,
Larry, the old link www, appliedgmc.com still works.
Emery Stora
> Larry
>> Thanks Ken,
Start by cleaning and flushing the window drain slots. That plastic package strapping material makes a good clean out tool , then flush with water.
If clogged it tops over on the inside onto the rug.
John Lebetski
Woodstock, IL
I just installed the door gasket 3 days ago. I used the gasket supplied by Jim and Nick at applied and 3M Black Super Weather Striping Adhesive. I
taped off around the door jamb so that the adhesive made a clean edge. I cleaned the surface with alcohol applied the adhesive to both the door and
the door gasket and let it tack off. Before it got tacky, I removed the tape so that I could get a clean edge on both sides of the adhesive. I started
at the top of the door and lightly applied the gasket from top to bottom working both sides of the door. Once it was all positioned I applied pressure
with a rolling wheel and closed the door completely.
The results are outstanding. I was very happy with the quality of Jim's gasket and 3M super Weather Stripping Adhesive. I absolutely would recommend
the gasket from applied.
Take care all,
Tom K.
Tom & Oki Katzenberger,
Kingsville, Maryland,
1977 23' Birchaven, 455 C.I.D., Micro Level, Howell EBL-EFI Spark Control, Macerator, York Air Compressor, 6 Wheel Disc, Quadra Bag, Onan W/Bovee
Ignition
> water. If clogged it tops over on the inside onto the rug.
Yes indeed. I cleaned them out but I'll do it again with that material ..usually use my penknife, thanks!
Larry
Thanks for the tip Tom, will check it out.
Larry
> started at the top of the door and lightly applied the gasket from top to bottom working both sides of the door. Once it was all positioned I
> applied pressure with a rolling wheel and closed the door completely.
> recommend the gasket from applied.
> Take care all,
> Tom K.
If you don't already have one, you should also install the "small rain
shield that fits above the door" which Jim mentioned. Since most GMC doors
don't seal as tightly at the top as around the sides of the door, water can
leak past the seal. The rain shield deflects most of the roof runoff to
the sides rather than letting it flow onto the lightly compressed rubber
seal. If the door is really loose at the top, it's time to re-curve the
door. Dan Winchester's posting is an excellent guide for that task:
http://www.dwinchester.com/gmc/Recurving_Door/Recurving_Door.html
> started
> pressure
> Take care all,
> Tom K.
> Ignition
