Digi-panel and other/NAPA sender
dave1
460
>BTW the NAPA sender - since it's recommended so much as a replacement, why
>didn't someone mention that it doesn't have the same spade lug
connection as
>the original. The one I got has a large solder post (at least that's
what it
>looks like to me) on top. Is there a mechanical snap-on connector for this?
The sender I got came with a new plastic housing. Use a pin or small
screwdriver to release the metal tab (at the end of the wire) from the old
plastic housing. Then snap the metal tab into the new plastic housing that
comes with the sender. The new housing will snap onto the new sender at a
right angle to the center line of the sender.
Before installing mine I tested it by placing it in boiling distilled water
(212 degrees) and got slightly more than 1/2 scale reading on the gauge.
Dave
73 Sequoia
