Nate,
Hows the mill doing? Sounds like you're still tussling with the tight
timing. I pointed this situation out to Chuck Stoddard when he came over
to survey his baby at FC. He was abit miffed at how sensitive twisting the
dist. was. I think that is why he suggested for you to send him the dist.
to check out.
Before I would hang more jewerly off of that motor, I would make sure the
basics are up to par.
Give Chuck a call & let him take a look.
The clouds are starting to part at the shop so give me a call if you get a
chance.
See ya,
Jim Bounds
>Emery,
> Was it much to install the Caspro Anti-knock unit? What all was involved?
>Did you have a HEI (IE. late model) distributor? Looks easy but you never
>know sometimes...
>Nate '75GB (getting chilly in) Omaha
>Date: Wed, 13 Oct 1999 15:35:54 EDT
>From: EMERYSTORA
>Subject: Re: GMC: Two Things - Never Mind!
>reference
>"dial" and my timing was set at 12 deg BTDC. Here's hoping that setting it
>back to 8 deg as specified in the Book + my newly rebuilt carb will give me
>some extra power. Larry Nelson, Springfield, MO, PB75 >>
>I had put on the Caspro knock detector which automatically retards the
>timing
>if it detects a knocking condition. With this unit you set the timing to 12
>deg BTDC with the vacuum line unhooked and plugged. You then reconnect the
>distributor vacuum line. If you hit a hill or perhaps buy some lower grade
>gasoline that causes a ping, the detector will back down the timing to about
>the 8 deg. range and then bring it back up after the pinging is gone.
>Emery Stora
>77 Kingsley
>Santa Fe, NM
to check out.
chance.
See ya,
Jim Bounds
>Emery,
>know sometimes...
>From: EMERYSTORA
>reference
>timing
>Emery Stora
>77 Kingsley
>Santa Fe, NM
