After the radio went in last weekend, I lost the dash lights. After
much looking at all the grey wires, I checked the fuse. I then replaced
it three times in disbelief that it wasn't the culprit. As soon as I
pull out the headlight switch the fuse fries. The good news is that
while I had the dash cover off, I found my flasher unit and now I have
emergency lights.
BTW, I installed a digipanel yesterday and it is great. It reads oil
pressure, engine temperature(you put a sensor under the thermostat
housing bolt, volts, and transmission temperature. You put a sensor on
the trans coolong line going to the radiator. There are preset alarms
for everything but the voltmeter. Easy to install and under $200
Walter 78 Royale
emergency lights.
Walter 78 Royale
