40 mile run ends with near disaster! My exhaust
leak might be from the intake manifold..is this
possible? I removed the air breather to discover
burned wires and the plastic wrap around them.
I had painted the intake manifold a few months
ago. When I had it running in the driveway I had
noticed a little soot around the " plate with
two small pipes coming out running to the carb "
This plate looked slightly curved upon inspection.
Meaning that it doesnt sit flat on the manifold.
I had put permatex gold on there before putting
it back together...big mistake. Looks like fire,
heat shot out from under and cooked the wiring
harness. BUMMER. I seperated the wires. Most are
ok. A couple had the insulation burned off. Now
my questions.
Anyone painted there intake manifold? Did the
paint burn off on both sides of the carb? My
paint did. Looks like a really hot spot there!
Right in the center of the manifold.I had the
heads off and reconditioned a few months ago.
Did I do something wrong? Could my timing be
off causing such a mess?
Help. Thanks,
Robert Teed 74 Painted Desert
my questions.
Help. Thanks,
