Damp Carpet/Water leaks
steven d. ferguson
874
The doors for the storage cabinet under the refrigerator had some water
damage when I bought my coach. It has been parked for 3 months now, the
fridge is "off" and dry and so is everything else above it. When I took
the
doors off today, I noticed they are still damp - water seems to run
down the
inside of both doors. >>
Sounds to me that it is the water lines (hot and cold) that run over
from the
bath module to the kitchen sink overhead in the area of the roof that
passes
by the front of the refrigerator. You might have a leak in this line.
If it
is a hole or "rub" spot you can buy a coupling from Home Depot that fits
that
line. It is called something like "Qest"
Exactly the same thing happened to mine.
Steve F.
What you are experiencing is normal and my coach had the same water damage
and it rusted the door hinges. It comes from a loose door seal in the
refrigerator, or possibley a crack in the lower shelf like in mine.
>the
>down the
>from the
>passes
>If it
>that
>Steve F.
