Good luck getting the nearby location. Sorry I told you stuff you already
knew; I'd forgotten your involvement with Eric at BS.
> Dave has volunteered the use of his driveway but another former GMCer that
> now lives in Arizona still has family nearby that has a shop/hookups/place
> to work. Fingers crossed on that one since its only 10 miles from here.
> Dave is 75 miles.
> And you and I are in a select group. I too helped Eric remove and replace
> the transmission you helped remove and replace all those years ago.
> Sent from Yahoo Mail on Android
https://overview.mail.yahoo.com/mobile/?.src=Android
> On Thu, Jun 22, 2017 at 9:45, Ken Henderson
> Jared,
> The use of a gantry in the cockpit is the best way to R&R the
> transmission. But it's not mandatory: You use a 4x4 or other such beam
> across the hatch opening, with 2 long eye bolts to support the rear of the
> engine. There are 3/8"-16 tapped holes in the rear of each cylinder head
> through which you can insert bolts through the eyes of the bolts. The
> transmission can then be removed using a transmission jack. I helped Eric
> Tanner do one at Bean Station a few years back. Not really a lot more
> difficult than with the gantry and hoists.
> Remember, you DO NOT want to remove the final drive -- just unbolt it from
> the transmission. WIth the rear transmission mount unbolted from and
> loosened (only) at the rear cross member, it will tilt to the rear. After
> unbolted from the engine, the transmission can be moved to the rear to
> disengage from the engine and the final drive with clearance to lower
> straight down. Wire the torque converter (through the round right side
> dust port) so it can't slide off of the input shaft.
> With these hints, you MAY be able to get an independent shop to do the
> R&R. If they won't accept hints, it may be the wrong shop.
> Dave Marchiando is a great guy, but not very out-going, especially since he
> lost his
wife.
> Ken H.
> On Thu, Jun 22, 2017 at 10:17 AM, Jared Kohl
> > I have a line on a replacement transmission. Just need a place to get the
> > coach towed to. No one local (Inc the damn transmission shops) are
> > answering any phones.
> > Trying to line up everything before calling Allstate again to get towed.
