CV Joint Boots
none
182
- -----Original Message-----
To: gmcmotorhome
Date: Friday, June 19, 1998 10:28 AM
Subject: GMC: CV Joint Boots
>I'm getting ready to rebuild my half-shafts and I've noticed in a couple
>GMCMI newsletters that its recommended you double wrap the clamps on the
>big end. This supposedly allows you to clamp the boot tighter(to avoid
>grease leaks) as friction is less with metal against metal than with
>metal against rubber. This seems overkill to me. If friction against
>the rubber is a problem, then a little silicon spray on the boot before
>applying the clamp should fix that.
>Any ideas?
>Patrick
>Patrick Flowers
>Mailto:patri63
>The GMC Motorhome Page
>http://www.gmcmotorhome.com
>Patrick......My business has been automotive driveshafts for the past 20
years. The clamps supplied with the boots fit more than tight enough if
they're put on correctly. I've never had one come back because it was
leaking grease.......Jim Davis
To: gmcmotorhome
Date: Friday, June 19, 1998 1:43 PM
Subject: Re: GMC: CV Joint Boots
>> Use a new superboot, the clamp is set to higher torque and will not
>> leak. The boot comes with enough hi temp grease to do the complete
>> job. Never saw a boot leak that was put on right and had the right
>> amount of grease in it. I have never done a GMC but many toronados.
>Thanks Thomas! I'm planning to use superboots. However, I'm going to
>use the Mobil1 grease to pack the joints and the bearings.
>Patrick
>Patrick Flowers
>Mailto:patri63
>Patrick.......The grease that is supplied with the boots is designed for
the type of loading that the CV shafts run under. I'd suggest you stick with
the ugly black stuff instead of the Mobil..........Jim Davis
Any ideas?
Patrick
Patrick Flowers
Mailto:patri63
Use a new superboot, the clamp is set to higher torque and will not leak.
The boot comes with enough hi temp grease to do the complete job. Never saw
a boot leak that was put on right and had the right amount of grease in it.
>Any ideas?
>Patrick
>Patrick Flowers
>Mailto:patri63
Patrick
Patrick Flowers
Mailto:patri63
Its fine but be sure you use a torque wrench to put on the clamps. You will
need a special clamp tool that takes the torque wrench.
where did you get the mobil 1 grease?
>Patrick
>Patrick Flowers
>Mailto:patri63
The mobil1 grease is widely available in most autoparts stores. I
thought it was approved by Mobil for CV joint use, but now I can't find
that information. I have emailed Mobil to ask them if they recommend it
for CV joint service. If they don't, I'll go with Redline CV2. It's
more expensive than Mobil1, but with the small quanitity needed to do
the bearings and shafts it's not that much of a difference.
Can't say the same about their oil. $10/qt. is too steep even for me to
rationalize.
Don't remember if Arch posted these two URL's:
Red Line Synthetic Oil Corp.
http://www.redlineoil.com/
Mobil1 Motor Oil
http://www.mobil.com/consumer/mobil1/index.html
Patrick
Patrick Flowers
Mailto:patri63
Pat I believe that the proper grease for the CV joint is now Green. At least
the grease that came with my boots was green.
>From: Patrick Flowers
>To: gmcmotorhome
>>Patrick
>>Patrick Flowers
>>Mailto:patri63
