See:
| Gene Fisher CA/OR/Palm Beach-GMC
| web page
| http://www.california.com/~eagle/
or check below:
| -------- REPLY, Original message follows --------
| Subject: Re: GMC: cruise control question
| Thanks, Mark.
| I tried it and it works.
_/ _/ _/ _/ _/ _/ _/ _/ _/ _/ _/ _/ _/ _/ _/ _/ _/ _/ _/ _/ _/ _/ _/ _/
| If anyone needs a replacement transducer take note of the following
| number: Checker Auto #36-102 ($60.99 plus core). Checker lists this one
| for the '76 Caddy Eldorado and the number cross references to GMC #2503
| 0712, the number shown in GMC dealer's computer as the successor for the
| one listed in our GMC Motorhome parts manual.
| The AC/Delco rebuilds have been discontinued. Cinnabar also says they
| are unable to get rebuilds, so I was happy to find one at Checker. It's
| rebuilt by A1-Cardone.
| Richard
| ----- Original Message -----
| To:
| Sent: Thursday, August 05, 1999 8:41 PM
| Subject: RE: GMC: cruise control question
| > Better too high a resistance than too low. The hold solenoid coil in
| the
| > transducer is usually the part that fails (electrically at least);
| > mechanically its the bearing on the eddy plate that goes first.
| > As long as the transducer will engage and hold, (and it probably will)
| don't
| > worry about it.
| > Note too that some original GMC transducers are 'three wire' units
| with a
| > separate signal lead to the dash cruise light. Only Buick/Cad (maybe
| some
| > Olds) used this configuration. All others are 2 wire with no engaged
| > (cruise) signal light. The 2 wire units will work just the same.
| > Mark
| > |-----Original Message-----
| > |From: owner-gmcmotorhome
| > |[mailto
wner-gmcmotorhome]On Behalf Of Richard
| Guthart
| > |Sent: Thursday, August 05, 1999 7:16 PM
| > |To: gmcmotorhome
| > |Subject: GMC: cruise control question
| > |I just purchased a rebuilt cruise control transducer from Checker
| Auto. The
| > |instructions which came with it contain the same detailed
| > |electrical and vacuum
| > |checkout procedures found in our GMC service manual. According to
| these
| > |instructions, however, the "resistance wire" which supplies the
| > |transducer's
| > |coil is supposed to read 22-24 ohms. The GMC manual says 38-42
| > |ohms. (Mine reads
| > |40.)
| > |Anyone know if I need to replace the resistance wire? Can I damage
| > |the rebuilt
| > |transducer by trying to use it without replacing the wire?
| > |Richard
| web page
or check below:
| Thanks, Mark.
| Richard
| To:
| the
| don't
| > worry about it.
| with a
| some
| > Mark
| > |[mailto
| Guthart
| > |To: gmcmotorhome
| Auto. The
| these
| > |transducer's
| > |ohms. (Mine reads
| > |40.)
| > |the rebuilt
| > |Richard
