This is exactly the kind of information that should be documented on
patricks site, ,maybe titled "confirmed correct parts for the GMC
motorhome". We discussed this same subject sometime ago but anytime a new
member comes on board it can come up again.
The correct water pump for the GMC motorhome MUST HAVE A 4 1/4" (not 3 7/8")
CAST IMPELLER WITH 6 CAST paddles. It should have part # 412265 AND MUST
HAVE A D24 stamped on it also. A cast pump with the same part # and a D2
or D11 stamped on it is not suitable. There may be other suitable part
numbers but I have not been able to find them. The D24 casting has a very
small cast bypass space betwen the impellers and the pump casting.
Just because a pump has a cast impeller, it may or not At 10:41 PM 12/9/98
>Mark,
>I just completed a job which included a new water pump. I ordered a new
>one through GM and recieved a steel impeller that was 3 1/2". I then
>ordered a rebuild and told my supplier to open the boxes and tell me the
>size of the impeller. He came back and said he had ones on the shelf with
>the same number with cast & stamped impellers, how about that! The OEM
>impeller on the water pump I pulled out was a 4" cast one.
>My sources do not have a special # for the larger impeller, it seems to be
>a matter of luck.
>I will have my suppliers check before they ship in the future!
>Jim Bounds www.gmccoop.com
>>A new Water Pump was mentioned from Eaton GMC.
>>Anybody know if this was one with a cast impeller of 4 inches or 4 and one
>>quarter inches? Does it make a difference? Which one does Cinnebar stock?
>>I'm planning to carry a spare but I want the correct one.
>>thanks
>>Mark '77 Palm Beach NY
>>Hemogoblin's.com
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
>Mark,
>a matter of luck.
>>thanks
>>Hemogoblin's.com
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
