Increasing pressure increases boiling point of water but not sure what the
increase is from 9 to 16 psi.
I'm sticking with 9 psi as it should be plenty if all else is working
properly.
Robert Shaw thermostat #330-195 (available from Autozone or Murray Auto
Parts among others) is said to be the best.
This high performance thermostat supposedly flows much more water than the
original one.
I read the original thermostat is the weakest link in the cooling chain
because even when wide open, it limits the flow of water.
Cost was about 5 bucks at Autozone.
Don
>Advice please:
>Why 9 lb radiator cap per original vs 14 - 16 lb? Have installed 16 lb cap
but
>doesn't seem to draw water from reservoir when needed.
>What is best thermostat - just had one lock up yesterday in mountains -
only 6
>months old. Seems to run a little hotter than should - gauge reads 3/4 at
>normal driving speeds (when thermostat locks up, goes to past hot real
fast -
>good thing I was watching).
>Need to buy these items now and would like advise.
>Thanx
>Lanier
properly.
original one.
Don
>Advice please:
but
only 6
fast -
>Thanx
>Lanier
