Yea Skip, Thought mine was alittle slow for a dual pumper, will O/H after I
get the Thomas pump, going to set-up Thomas just as Dana except drill new
holes for Thomas and O/H Dana/Hadley so I can switch if need be. After O/H
of Dana/Hadley might check which one pumps up the fastest. Just to see,
anyway I'll have a spare if need be! Thanks for info of you're better
pump!!!
PS water pump(one I removed had open pump fins/blades? as gateway was
covered both have six blades/paddles)?, stat( was thinking of going to 190
if they had em, any comments?), and all hoses/belts out for replacement,
also water sender, putting in the NAPA sender p/n (But its a mind
trip, now on going to see the temp. gauge up above the half mark!!!!!
OEM?(looks funny, but been sipping a few, and temp up to 114 in Mohave) fan
sitting as removed off GMC in a box have been working real good and want to
keep that way!!!!
Ron&Gina
73 Pumpkin-Rose
Ft. Mohave. AZ.
To:
Sent: Saturday, July 31, 1999 1:24 PM
Subject: Re: GMC: compressor time
> Hi Ron, Hi Chris,
> I just filled my tank only in 3 minutes and 45 seconds on a newly rebuilt
Dana.
> I'm happy about it. Now if I can just find the rest of the leaks!
> Skip
> '75 Avion in western MD
> > Hi Chris, I'm new to this so not much help, But my 73 takes that long
from 0
> > Tk. press. to 130 thats the tk.
only.(under pass.wheel well, guess its
the
> > bigger tk. so I guess overhaul of pump is in order) Air bags holds
press.
> > good. Still have alittle leak somewhere between bag controllers to tank,
> > press switch, just replaced my tk. check valve which eliminated my pump,
I
> > lost about 10# in two days don't know if this is acceptable of not for
this
> > system with air bags in hold position and holding. Hope this helps.
> > Ron&Gina
> > 73 Pumpkin-Rose
> > Ft. Mohave, AZ.
> > From: chris izzig
> > To:
> > Sent: Saturday, July 31, 1999 8:45 AM
> > Subject: GMC: compressor time
> > > my compressor fills the coach in about 6 minutes. is that normal?
> > > thanx chris 75 gb
> > > ps you may have answered this before but im having comp problems
> > > Join 18 million Eudora users by signing up for a free Eudora Web-Mail
> > account at
http://www.eudoramail.com
