"But weighing each axel tells you nothing either as indicated by Cinnabar=
s
research. No two tires on the GMC motorhome ever carry the same weight,
even on the same bogie side."
This is one that has never been properly explained to me.
Given the configuration of the rear suspension (on a stock coach with one=
air bag per side), unless parts were seized etc., it would seem to me tha=
t
the suspension would share the weight very equally between the intermedia=
te
tire and the rear. =
This would of course be limited by scale accuracy and the ability to have=
the coach equally level during the weighing of both axles but both of tho=
se
should be able to be reduced to relatively minor errors.
Can anyone tell me why, given the suspension geometry, on a stationary GM=
(no dynamic forces) the lead and the trailing wheels would not carry very=
close to identical weights?
Regards
Gary Zingle
s
t
te
se
Regards
Gary Zingle
