combiners-any suggestions
ronald b. kazi
523
I am seriously considering a combiner as my isolator seems to have given
up the farm (no charging on the house battery). I located one that
interests my love for gadgets.
http://www.hellroaring.com/bic75300.htm
The three bank version appeals in that I still have a battery in the
generator compartment (deep cycle, large) that I would love to use as a
second house battery to power the rear fuse panel and to hookup to the
a/b solenoid to allow them to work together when boondocking.
I can always do the jumper cable thing if the starting battery is dead.
Any suggestions as to which one to use?
Ron and Julie
73 Painted Desert
Thanks for the suggestion. I have a switch that will do that for me. Havent
made up my mind yet on the combiner/isolator.
Ron and Julie
> Ron and Julie; If you do decide to keep it stock and replace the isolator (I
> just did), bring a wire from the Pos. terminal of the rear battery to the 12
> volt bus bar where the buzz box connects and run it through a switch. You can
> turn it on to supplement the power to the 12 volt house bus bar and turn it
> off so not to effect any other system. I have used mine that way for 20
> years. The only time I really use it is dry camping in the cold so as to keep
> the heater fan running all night. My cost on the 120 amp 3 bat isolator was
> around $68. Let me know if you decide to replace it. Dean Hanson
Ron,
I've been considering the Heart Interface(www.heartinterface.com) Pathmaker
for a combiner. Looks like a neat unit, but I'm still undecided too.
Patrick
> for me. Havent made up my mind yet on the combiner/isolator.
Dont think I will get to it before the Colorado trip. Back is still out and I
havent gotten the coach to Ken Frey yet to do the transmission leak, alignment
and anything else I can afford.
Ron
> Ron,
> Patrick
Yep - 100amp/3bank. $164 at Performance Yacht:
http://www.pyacht.com/heart_interface_pathmaker_access.htm
Might be some better prices elsewhere, but that's an indication.
Patrick
> In a message dated 07/19/2000 12:13:06 PM Central Daylight Time,
> > Pathmaker for a combiner. Looks like a neat unit, but I'm still
> > undecided too.
> Patrick
> Are you going to use the 3 battery one? Thats the one I am looking at.
> Have not done much about it. Do you have a current price?
> Take Care
> Arch
