Cockpit window leak found
Keith V
3,607
407
83
Ive had a persistent leak in the cockpit windows. I found someone ( probably me ) sealed up one of the drain holes. I opened that up and the leak went away, almost.
If I'm camping on flay ground it's pretty dry, but here at home I park nose slightly downhill. that causes a leak.
Finally got to investigate and I found something weird.
The cockpit windows have a track for the slider and then an inside track that is unused.
There is a square hole connecting the slider window track to the inside track. water can pass through to the inside track.
Once in the inside track it can just run out the front of said track. The front of the inside track is open so being nose down water just runs out onto the floor.
Plugging that square hole should keep the water in the slider track and out of the coach, hopefully.
Reactions: pvfjr and RF_Burns
