Cockpit Noise
cbwood
101
>Interesting. Can you be more specific as to where this area is? Is the foam
>you are referring to on the inside or the outside?
After you open the drivers side access hatch, look directly above the wiper actuator rods and you will see where the bottom of the dash meets the front of the coach..The foam was? between the bottom of dash and the coach 'skin' right below the windshields.. I sealed from about the middle of the access panel to the side of the coach. Make sure ur foam thingy has a long tube on it, otherwise you have to physically move the wiper mechanism out ot the way.(Just move the wipers on the windshield).Really havent check passenger side yet..
HTH
LMKHIW
CBWood
77 Kingsley
MWC OK
Get free personalized email at http://www.switchboardmail.com
