Gene,
It depends on how much of a purist you are when replacing parts on your
coach. The clearance lights cost almost 13.00 apiece. I found a set of
lights in J.C. Whitney that cost 20.00 for a set of 5. Part
for the amber and part for the red. A more modern style but
they look good. If you must have the original style plan on spending
more than 150.00 plus misc. parts. When I check mine last summer
because they were not working, 9 of 10 were rusted and corroded that
they were junk. Depends on how much you want to spend.
J.R. Wright
GMC GreatLaker
Michigan
> Has anybody replaced their clearance lights lately? Using the regular OEM or
> going to anything new? The light back in the Gen-Batt compartment is it the
> same as the clearance lights? My bulb is alittle different, but corroded etc.
> I can't really tell if it is the same or not. It also has a switch (toggle)
> back there.
> Thanks,
> Gene Hyche
> '77 Palm Beach
J.R. Wright
GMC GreatLaker
Michigan
> back there.
> Thanks,
> Gene Hyche
> '77 Palm Beach
