Charging Battery
neely butler
204
Al, Pat, Rick, David, Gil, Emery, & (any I might have over looked)
Thanks to you all for answering my question. With my memory such as it is I
think I will just buy a trickle charger for the engine battery so I won't
have to remember to disconnect it when starting the engine. I would take you
up on the deal, Emery but it is so far from Lebanon, TN to Santa Fe, NM, and
I hardly ever get out that way. Thanks to you all.
Neely B.
Neely... buy a combiner instead of a charger and you update your isolator and
reduce your drop across the batteries and charge both at the same time. You
wont have to remember to plug in the charger to the front and the charger to
the rear will charge both batteries.
al
> Neely B.
