Norm: Thanks for the info. Wll look into one locally, and if not, will
ask for the number.
> Date: Thu, 29 Oct 1998 22:11:41 -0600
> From: "
mr.c"
> Subject: Re: GMC: Cell Phones-Antennas
> Norm, could you tell me the brand of antenna that I can use on the
> glass. "On Glass Antenna's in which case again use the 5db Gain vs
> 3db" It might be esaier to buy that one if one knew which one to buy.
> Thanks
> Al Chernoff
> Al
> Motorola Direct sells the 5db Gain Antenna ( Kit K18)
> This Antenna is designed to operate on cellular systems Frequency
> Range:825-895 MHZ
> Kit includes everything needed:
> Outside transducer with whip
> Inside transducer with foil decal
> RG 58u Coax cable
> Mini UHF connector and window cleaning pads (TNC connector optional)
> NOTE: Directions are included This is one time You must read them !!
> and get it right the first time No second chance with this antenna Kit
> If putting on front window beware of whiper blade path (Helpful hint)
> check with your local carrier for this antenna or e-mail Me for Motorla
> Phone #
> Also made by Mobile Mark which I think is sold by Radio Shack
> on both 5db gain on- glass antennas enclosed is the Foil Decal which
> must be properly installed for effective performance.
> What I like about this antenna is the fact that it is very thin and
> flexable so if hit will not damage the glass or what ever it hits
> also the mast is removable to allow a dust cover to be put on the Coach
> and for theft reasons also.
> What i don't like about it is it requires thinking to install 8~}
> but if you take it slow and read the directions ...no sweat
> Make sure you request the 5db Gain for it comes in the 3db gain
also.difference being 5db has the coil on the mast and comes with the
> special foil for optium performance.
> Hope this helps
> Norm
> normillett
