CAUTION front rotors need to be replaced
thomas g. warner
1,863
Remember in order to replace the rotors you need to pull the front wheel
bearings. If you do not have a wheel pulling tool don't trust it to just
any shop or you will end up with a disaster.
>went in to get front disc pads replaced today - found out I need both
>rotors replaced instead - one is bad shape - one is OK but too thin to
>turn - I am going to put new pads on the bad side so i can leave on the
>trip this weekend but I know the rough rotor will tear them up fast
>I am going to be in Calgary and Columbia MO for extended stays in the
>next 3 weeks - is there a good place in either where i could get good
>prices on the rotors and have experienced mechanics to put them on?
>also I think I have one rear wheel that needs an alignment touchup - I
>can visually see what looks like toe out and positive camber on the
>driver side front rear wheel and the tire is cupping on the inside edge
>- is there an experienced shop in either Calgary or Columbia?
>also - what are tire prices like in Calgary for 8.75 16.5D - i could use
>a couple tires - might be able to save some on the exchange rate
>thanks
> ron keener near Austin, Texas http://MidAmericaBreedingTech.com
> * proud owner of classic 1978 GMC Birchaven motorhome
