Larry, you wrote:
I removed the Jacobs ignition system today in preparation of installing
the
Caspro EKE. The whole works will go on ebay along with some digitizing
tablets (who knows what those are?).
>From one good ole' boy from Missouri to another, I would recommend that
you use connectors when you connect your Caspro EKE, rather than hard
wire. One of the two failures I have had on our GMC was due to the EKE.
A few years back, as I was preparing to leave a GMCWS rally, I could not
the engine started. After using the ignition tester that Duane has
recommended, I found that I did not have any spark and it showed the
module was not working. I put in my spare module and still no spark.
Luckily, Duane had not left the rally so I went to him for help. We
installed his spare module and still no spark. He asked what was that
little box I had connected to the distributor and I said it was a Caspro
EKE. We disconnected it and the engine started. that is why I
recommend you use connectors so if you have a similar problem with no
spark you can disconnect the unit and go back to the OEM configuration
before you do any other testing. That is my 2 cents worth.
Chuck Aulgur
La Mesa CA
Formally from Marshall MO
Wife From Springfield
the
Chuck Aulgur
La Mesa CA
