Can I remove the plates by the door?
lts70
Member
Apr 2, 2021
92
59
18
Idaho
My original air bag decided to rupture right after I purchased the coach. Luckily it happened while it was in storage and not on the road. When the coach rapidly descended on the right side the t-skirt bound on the tire and cracked the fiberglass right above my wheel well. I plan on cleaning things up and using 3M panel bond and a plate behind the crack to get things sturdy.
My question is in the same area there are three placards that are starting to look pretty tired. Would it be legal to remove them and reattach them under the hood somewhere out of sight?
There are actually some RV parks that will not allow any RV without the RVIA medallion, probably not the kind of place you will be staying, but better to leave it exposed to be safe. The other two plates are just conversation pieces, if they bother you then toss them. I'm not sure "Original Idaho coach" has quite the same cache as some other states :ROFLMAO:
Reactions: lts70 and tmsnyder
