Bright-Bar entrance door handle
Don Jaksa
577
393
63
I got this to install on my coach
Is it supposed to be a Herculean task to insert the Lucite
into the chrome handles?
The bench grinder seems to be the only choice
Anyone have experience putting this together?
On careful examination it appears that when the lucite rod was heated to form into the handle, it resulted in slightly flattened rounded ends.
I tried to take pictures but could not get a good image.
Using a micrometer the opening is 1" and the Lucite rod shows is 1/16" wider on one side on both ends, obviously where they applied pressure to form the bend
If I tried to insert the rod as-as the mount would eventually crack...unless the flatness does not extend beyond the tip
I'm going to round the ends and try that
By using a file and sanding block I was able to round the flattened out to round again.
They fit nice and snug now
I guess it wasn't that hard
First fitting
Okay, Count me into the RAGUSA door handle club
I just have to wire it to the porch light
I heck of a lot easier to install then the screen door
Night-mode...Does it attract predators?
I might add a blue GEL or something, the white seems...
I'm glad it's not RED
