Earlier today I responded to a question from Jerry Lader about a problem
with the brake lock that I'd mentioned in my "Trip Report". I had intended
my response to go the whole group since I was "fishin'" for comments, but
didn't notice it was off net. So here's Jerry's question and my response
for y'all to check for faulty logic. Have at it!
> >Hi Dave,
> >Did I read that you had trouble releasing your brake valve on your recent
> >trip? I am very interested in installing a valve like you have. Please tell
> >me what you found wrong.
> >Jerry Lader Cad. Powered Edgemonte(CADDYSHACK)
> > hot and humid today in Memphis
Response:
> As I understand it, the way these things work is related to why they can
> also lock up. When the lock is actuated, pressure is already being applied
> to the wheel cylinders by having your foot on the brake pedal. The lock
> simply prevents that pressure from being returned to the master cylinder
> until pressure greater than what is being held back is applied from the
> master cylinder side. When that happens, the pressure is the same on both
> sides for an instant allowing the valve to retreat and fluid to again flow
> in either direction. It locks up, or won't release, when you can't generate
> greater pressure with the pedal.
> I believe this happens when the pressure being held back increases due to
> radiated heat along the various brake lines. Both times it occurred, we
> were at elevation and set it after pulling a grade and while stopped on hot
> blacktop. When it happens, you have two choices; wait until the lines cool
> a little (might be1/2 hour), or crawl underneath and open a bleeder valve.
> For us, waiting is the only option.
> I'm not sure anything is really wrong. Its just a circumstance that isn't
> present in the lock's normal application.
> This is admittedly theory at this point, but until someone offers a more
> plausible explanation, I'm going to assume it to be valid.
> Last, here's what I'm planning to do about it. I'll have by mechanic
> install a bleeder valve just after the lock and accessable from under the
> driver's side engine compartment door. My wife can the be taught how to
> release enough pressure to get us going again. Since we carry brake fluid,
> we can check and fill the master cylinder if necessary.
> I hope I haven't confused more than clarified, and that if I'm the one
> confused, one of the GMCnet "experts" will straighten me out.
> Dave (advisor/navigator) & Dege (ALL else), '76 Royale, Santa Barbara, CA
> >Hi Dave,
Response:
