Brake lights wont work...
shan rose
827
Any ideas? In thinking the BOO switch
73 Canyon Lands, (a.k.a. The Yellow Submarine) West Los Angeles CA
Actually the rear signals dont work either. Bad chassis ground??
Duce,
If you mean the rear turn signals, they are the same filament as the brake lights.....
If it were just a bad chassis ground, things back there would work badly or strangely because the light assemble would be grounded through the marker
light filaments to the front frame.
I suggest that you get out the chassis wiring diagrams and carefully diagnose the system.
All of those signals (brake and turn) go through the turn signal switch and that has a major junction down on the steering column. If things aren't
good there, they won't be good any where.
What other rear lights are out? Tail, clearance, License plate light? Turn signals are the same filaments as brake lights. I assume that you
checked the fuse.
Exercise the 4 way flasher switch. It has to go through there to get to the rear.
John Lebetski
Woodstock, IL
Clearance lights still work wheres the fuse looking over the wiring diagram cant find it :-/
Look at the wiring diagram on the left side fOr "Directional Signal Haz and stop". It shows a 20 amp fuse feeding all of that. The fuse is located
inside the glove compartmment behind a steel plate held in with one screw.
