Bogie greasers
s-m-h
135
1
I installed the quad bags I robbed from my parts coach today and while I was "picking" I pulled the bogie greasers that had the dual zerks. Took me a
while to figure out the concept but now that I shot some grease threw them, I sorted it out. Pretty cool - I'm sold! Only thing is, only 1 of the 4 I
pulled came out with the brass fitting on the end with the O-ring. I suspect this bit is special order/custom made(correct me if I'm wrong) but I
wonder if it still better than stock to install them even w/o the end bit? I suspect yes, but looking for advice.
TIA for the input.
Stay safe.
Shawn Harris
North Vancouver,
Canada
1977 Palm Beach 403
My greasers are DIY from here:
http://www.gmcmhphotos.com/photos/bogie-greaser-mod-3/p6258.html
I don't recall using O-rings...
Rob
Victoria, BC
76 Royale - Rear Twins/Dry Bath
> TIA for the input.
> Stay safe.
The o-rings are kind of important. Sometimes they get stuck on a burr inside when inserting the. You can get rid of the burr by chasing out the hole
with a greased drill. Unfortunately I do not remember the size.
That was the more original on made by Dick S of the Great Lakers.
We market the ones with the flaired copper ends.
All designed to showe grease to the back area and the front.
On Wed, Apr 1, 2020 at 7:40 AM Ken Burton via Gmclist <
> hole
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
http://www.gmcrvparts.com
Thanks fellas.
Yes, I think you are right Jim. The tube on mine are made from sort some of soft metal with threaded ends in which the brass bit with the o-rings are
attached to. I think I will just replace the tube with copper and flare them to match the bore as others have done.
Shawn Harris
North Vancouver,
Canada
1977 Palm Beach 403
I have been around long enough to remember which design came out first and
why.
There are not many from 1980 that are still around to tell you.
On Wed, Apr 1, 2020 at 8:16 PM Shawn Harris via Gmclist <
> Thanks fellas.
> Shawn Harris
> North Vancouver,
> Canada
> 1977 Palm Beach 403
