Bogie bracket and bottle jack
thomas g. warner
1,863
I have a bracket like you described and although I can get it connected to
the slot under the bogie bracket when a tire is flat, there is not enough
room to get my bottle jack under it. There is not enough room to get a
floor jack under the bogie and still get a bottle jack under. I have not
came up with an answer yet.
>> Ricki what do you do when one tire is deflated and the jack and bracket will
>> not fit under the bogie bracket?
>Tom,
> Must admit I've not had a flat, so I'm not certain. Pretty sure the
>bracket would still hook in, as the slot it fits extends part way up the face
>of the bogie bracket. Whether I could still get my bottle jack under it I
>don't know. Not too worrried as I also carry a lightweight 3 ton Chinese
>floor jack, which would almost certainly fit under the bracket, or under
>something. ;-) (Just have to be real sure the coach can't roll when you let
>it down again. 8-(
>Rick Staples
>'75 Eleganza
>Louisville, CO
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
To get a little more room under the bogey, have you tried raising the side
with hte flat all the way up and then driving the good wheel up onto a
couple 2X4's?
Worked for us once.
HTH
Dave (& Dege), Santa Barbara, '76 Royale 26'
___________
/_][__][_] [_] | "SR JAMES"
*-O------OO--*
