Dick.
I am catching up on old posts as I was away on holidays. It does not
look like you got your answer.
The relay is Standard RY-12 (standard is the brand name) $17.00 CDN.
I lost my high speed fan on my trip. Before you buy the relay, jumper
from the pos. battery to the red and white striped wire on the relay.
Don't pull the wiring connector off, just touch the jumpered wire into
the connector. Have the fan switch on high and the ign.switch on. The
fan should run.
My coach is a '73 and power is supplied to the fan from the alt. when
the engine is running just as Gene has stated on his site. If the engine
is not running then there is no power to the red/white wire.
I found that the problem was not the relay but the in-line fuse near
the fan. My fuseholder was "cooked" from all the years. It crumbled when
I tried to get it apart Someone else just in the past two weeks had
this very problem.
Go with a tripable breaker if possible to replace the fuse. Hope this
helps.
Regards, Gil
fan should run.
this very problem.
helps.
Regards, Gil
