blower motor/AC/heat
The ground wire from the harness has to be firmly attached to the motor housing to complete the ground path for the motor, which is internally
grounded to the motor housing (unless it's an aftermarket blower motor that has a separate ground wire).
Terry Kelpien
ASE Master Technician
73 Glacier 260
Smithfield, Va.
If you suspect that that capacitor is bad, you can just eliminate it. It's purpose is to reduce or eliminate the fan motor noise in the radio. If
you do later notice fan noise in the radio then replace it. Most of those noise suppression capacitors are shot after 40 years.
It sounds like you found the ground wire that is connected to the fan motor and fixed your problem. If you have a star or tooth washer handy, install
it between the wire lug and the motor frame. Then re-tighten the screw through the motor frame and into the fiber glass. Be careful not to strip the
screw hole out in the fiberglass.
The connection that you found loose or corroded is a common failure on Gm vehicles of this era.
Good luck. It sounds like you are making good progress on the wiring issues on this coach.
> ...It's ALWAYS the ground. ...
Only when you can't find anything else. You might say it is always CONNECTIONS. A lot of times there is corrosion in the space connectors. Sorry I
didn't think of that and mention it. As a communications guy, I didn't work on much stuff that was 40 years old and exposed to the elements. The first
assumption we always started with was "if it had been working, it is not the wiring infrastructure." That made us look at active components (like the
fan motor and relays).
Not true in automotive stuff that vibrates going down the road and has wide swings of temperature and humidity. Seems a lot of the time it is
connectors.
The Oldsmobile diesel Cutlass had a connector in the glow plug circuit that was installed to catch dirt. If the assemblers had flipped it over in the
wiring harness, I might never have had to figure it out, disconnect it, clean the dirt out of it, and polish the contacts, to get the glow plugs
working again.
73 23' Sequoia 4 Sale
Upper Alabama
"Highest price does not guarantee highest quality."
When I attended General Motors training school, one of the first things
they taught us about automotive circuits was "90% of all electrical
problems are conductor related, either wires or connectors". Been true for
me for 40 years or more.
Salem, Or
78 GMC ROYALE 403
> Sorry I
> first
> connectors.
> the
> working again.
> Upper Alabama
Do not forget the apc cable
> Jim Hupy
> Salem, Or
> 78 GMC ROYALE 403
> > Sorry I
> > first
> the
> > connectors.
> in
> > the
> > working again.
> > Upper Alabama
> I don't understand how anybody is successful in grounding anything to fiberglass.
Terry,
That is why boat people only buy 2 conductor.
I have run a return for everything that I have put in and a few others that were there already.
If the fiberglass the screw is threading into is loose, you could drill a 1/8" hole in the fan's metal mounting flange close to the existing ground
point. Then move the existing ground wire to this new hole using a #8 screw with a star washer and some anti-oxidant grease. The screw will then be
fastened directly into the metal fan housing. That should last a lifetime.
Bruce Hislop
ON Canada
Hubler 1 ton front end
