GMCers,
Ragusa sells a temporary replacement airbag rod, complete with rubber pads
and hardware for $38.00.(RV-08)
http://www.ragusarv.addr.com/
Peter
Colorado
To:
Sent: Sunday, June 25, 2000 7:52 AM
Subject: Re: GMC: Block and Pin
> you might have a point here. I have not used this rod. I have been lucky
> and have not had a bag failure. I would be really mad if it did not work
> when I needed it, but I am not going to remove an airbag to test it ;>)
> Maybe someone who is in the middle of changing a bag can test it for us.
> I think the design came from an old article in the GMC international. I
> might see if Bdub's index can find it.
> gene
> >ene,
> >Have you tried your bag rod? It looks simple enough, but I wonder about
the
> >dimensions.
> >Right now I have a block of wood with notches on the end. The idea is
> that you
> >insert the block under the air bag to keep it up. I don't know if it
would
> >work. I copied one that my neighbor made. He never tried his either.
> >I think I'm going to copy your design. I'm little worried about the
> block of
> >wood approach. I'd would be easy to insert because you wouldn't have to
> remove
> >the bad bag, but I think the block would split after a few miles.
> >Richard Waters
> >'76 PB, Troy, MI
> >> Hummm
> >> well no one is answering so here is the rod my PO had in my coach. I
have
> >> seen pictures of the block of wood, but this seems easy to carry.
> >> http://albums.photopoint.com/j/ViewPhoto?u=128904&a=2066855&p=23275323
> >> It is made up from a 3/4 inch threaded rod with a 3/4inch pipe over it
and
> >> two washers. The dimensions are the following.
> >> 3/4 inch Threaded Rod 18 inches long
> >> two 3/4 inch nuts
> >> 3/4 inch gal. pipe 15 inches long.
> >> two each 2 inch washers
> >> If you blow an air bag just remove the bag and use this in place of the
> bag.
> >> gene
> Genef -- 77PB/ore/ca
> GMC MOTORHOME INFORMATION
> mr.erf
> http://www.california.com/~eagle/
Peter
Colorado
To:
> gene
> >ene,
the
> >dimensions.
> that you
would
> block of
> remove
> >Richard Waters
> >'76 PB, Troy, MI
> >> Hummm
have
and
> >> two 3/4 inch nuts
> bag.
> >> gene
> mr.erf
