My newly acquired '77 Birchaven came came equipped with a VERY large hole in the black tank where the outlet fitting used to be. (As a side note, both
the rear bath units I looked at had similar black tank problems - is this a known design anomaly?)
First question: is Jim's GMC-4 tank the correct one for my coach? https://www.gmcrvparts.com/product-p/gm23-23.110.5.4.htm
Second question: If that is the correct tank, does it come as pictured without holes for the toilet and vent connections - i.e. do I drill them
myself?
Third question: Is this replacement tank ABS material or is it something else that needs a special cement for making connections to the tank?
Fourth question: While I am replacing the tank would it be worthwhile to install some sort of flushing mechanism (like
https://www.gmcrvparts.com/product-p/gmrv11-0348.htm ) instead of relying on the 'hose and nozzle down the toilet' ritual?
Thanks in advance for any advice.
Stu
Stu Rasmussen W7QJ
Silverton, OR
gutted '74 Eleganza II (for sale now)
'77 Birchaven
myself?
Stu
Stu Rasmussen W7QJ
Silverton, OR
'77 Birchaven
