David.There's an old saying that goes. There's always more then one way to =
skin a cat. And you covered another method of performance timing. I build, =
and race engines that are out on the edge of maximum torque at full throttl=
e in the 7 to 8,000 RPM range. I'm looking to get every half a foot pound =
of torque at the end of the crank. And there have been times that I've twis=
ted the end of the crank off. I machine down my oil pumps to reduce the oil=
volume out put of that pump. That detail helps to increase engine torque o=
ut put. I set the 4 carbs, and timing to the air temps, humidity, barometri=
c pressure, and gas that I'm using THAT day. ( As I bring my own tested gas=
with me ) All these change from day to day. I'm so close in timing that a =
settings I use one day. May blow the top of the piston out the next. Bringi=
ng this close of settings this close to our GMC's bring it's own issues. As=
the gas we get one day. May not be the same the next day. And all the ite=
ms listed above have changed. And with all of these changing ranges. How c=
lose to maximum timing advance do you want to get. The GM factory specs are=
listed to handle all of these changing conditions. With a safety factors i=
ncluded. So is one way better then the other. That is all in your comfort =
range. As for me. My stock 78 Royale, 403 with a 2-1/2 exhaust, no heade=
rs, and a 3:70 FD. With Linda's lift van I have a GVW of 17,000 lbs. With t=
he enclosed race trailer I'm at a GVW of 21,000 lbs. All with factory stoc=
k timing. That's my own personal comfort zone. Bob Dunahugh
